GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,135 REPLIES 16,135
>>>>> If you performed a factory reset during your initial troubleshooting, you'll need to do this:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Mude a data do seu dispositivo para 8 de março ou anterior, tente conectar o Chromecast novamente e faça a instalação normalmente. Depois disso, ele vai receber a atualização automaticamente.
Quando terminar, basta colocar o seu telefone de volta na data atual.
Espero que ajude.
NikeshAil
When u r going to fix this problem
>> If you performed a factory reset during your initial troubleshooting, you'll need to do this....
Marjo
Bonjour
J'ai réinitialisé ma chrome cast
Est ce possible de m'indiquer les étapes à suivre
Merci
Gbond2
Changez la date de votre appareil au 8 mars ou avant, essayez de reconnecter le Chromecast et effectuez l'installation normalement. Ensuite, il recevra la mise à jour automatiquement. Une fois terminé, remettez simplement votre téléphone à la date actuelle. J'espère que cela vous aide.
SagerWU
要多久呢?
>> If you performed a factory reset during your initial troubleshooting, you'll need to do this -
KyleShin
It still doesn't work to me. When does a Google fix this issue?
  >>>>> If you performed a factory reset during your initial troubleshooting, you'll need to do this:
johnnyzero2
For all the people who performed a factory reset during their initial troubleshooting, this procedure will allow you to reconnect your Chromecast to your Wi-Fi network, so that it can receive the firmware update fix that Google started rolling out on 3/13.
1) Temporarily set the date on your smartphone (or tablet) to March 7, 2025 or earlier. If you don't know how to do that, see below.*
2) Use the Google Home app to re-setup your Chromecast by adding it as a new device (+). You still won't be able to cast, and the device will be grayed out in the Home app, but that's ok. Most importantly, it'll now be reconnected to your Wi-Fi network so that it can receive the firmware update fix.
3) Change your phone's date/time setting back to Auto now.
4) Sit back and wait for the firmware update from Google to be installed. This should restore your Chromecast to full functionality.
Note: Supposedly it's being done as a "phased rollout", so it could take a while for the firmware update to hit your Chromecast. Also, some have reported that power-cycling your Chromecast (unplug/re-plug the power cable) will sort of "provoke" the firmware update to be installed. Patience.
*How to change your phone's date/time settings:
For iPhone/iPad: go to Settings, General, Date & Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
For most Android phones/tablets: Settings, General Management, Date and Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
***Google REALLY should pin this information to the top of this support page!!!***
SzilardSz
I would like to know where the chromcast troubleshooting is going? I am in a rather awkward situation because of it. Therefore, it is necessary to give a deadline. SOS!
Thank you.
Luquelme
I reset my device. And now?
Jar3
Acabo de escribir medía hora y como dije que a Google no le importamos, el mensaje no salió, error,
Rosinaldo
eu preciso do meu aparelho funcionando perfeitamente , afinal eu não paguei por um produto com data de validade , se não resolvem da maneira fácil irei tentar na vara civil , mais não vou aceitar mas um desrespeito ao consumidor , são dias sem poder ver um filme , pode até ser algo inútil pra vcs que tem o mundo aos seu pés ou quase todo o mundo pq eu não  faço parte desse grupo , ou resolve o meu problema ou eu vou entrar na justiça e pedir um ressarcimento pelo prejuízo financeiro e emocional causado  por vcs !!
 Resolvam o meu problema !! Já não tenho mais pasciencia
Ana9
Estou até hoje tentando configurar e não consigo, aguardando essa resposta e nada ainda
 >>> If you performed a factory reset during your initial troubleshooting, you'll need to do this....
Wendel77
MDS gente por favor vocês estão nos deixando na mão por conta desse erro de vocês, tá péssimo essa demora
 >>>>> *If you performed a factory reset during your initial troubleshooting, you'll need to do this:
JZKR
Soy adulta mayor y me mi única entretención arreglenlo pronto mi nieto me lo reseteo ,necesito ayuda para volver a usarlo muchas gracias
SergiTallon
Buenas tardes, el pasado viernes escribí un mail a soporte de Google indicando esta solucion que te voy mostrar y me respondieron como sigan tuviera el problema... sin más... ahí va como yo lo arregle:
De: Sergi Tallon
Date: vie, 14 mar 2025, 23:06
Subject: Solucion para que se actualize el certificado de Google ChromeCast en dispositivos que se han restablecido de fabrica en el fallo del 9 de marzo del 2025
To: chromecast-support-eu
Buenas noches,
La Solucion para que se actualize el certificado de Google ChromeCast en dispositivos que se han restablecido de fabrica después  del fallo del 9 de marzo del
2025, es tan fácil como cambiar el día al 1 de Marzo del 2025 en el telefono movil que se quiere sincronizar/configurar/agregar Chromecast a Google Home nuevamente desdey volver a sincronizar de forma estándar desde Google Home.
Una vez está establecida la conexión con el WiFi en Chromecast, automáticamente se actualiza nuevamente el certificado y ya vuelve a funcionar.
Saludos,
Sergi Tallon
miridk
This is not an answer, this is a reply! I paid for the product, rollout fix via BT instead of wifi, done, can't be that hard or write me I'm a real dev not some pseudo junior dev like the ones you seem to hire.
Interesting. Are you sure the Chromecast hardware even supports bluetooth? If so, that could be the solution that Google eventually (if ever) comes out with.
For those who don't feel like waiting for that, the "date" workaround works just fine.
Jar3
Dije que, hace años que vengó luchando con este tipo de problemas, hackeó de cuenta , hackeó de dispositivo, y saben que respondieron, 1 cambie la contraseña, 2 si no funciona cambie la cuenta, 3 si sigue, comuníquese con su proveedor, y si aún así no funciona cambie el teléfono, pero si tampoco llega a funcionar, mudese a la Antártida seguramente ahí no va a tener problemas
rosianenunes079
Quando que vai voltar a funcionar
mreto
Danke , mit der datums anpassung auf dem smartphone funktioniert der chromcast wieder.
Jheymissom
Ja restaurei a configuração de fabrica
Georgia3
Hace 3 días que no me funciona el chromecast. Cuando estará funcionando
vitaintrasferta
I do the factory reset of the Chromecast 2nd gen.
---->> If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Jar3
Siempre hay algún chupamedia que habla maravillas de estás empresas, vos tenés un problema y ellos de inmediato te llaman , te invitan a sus oficinas para que lleves tu equipo y te lo revisan ahhh y te dan un cafecito, dejemos de joder a alguien lo llamo personal de Google alguna vez, alguien tuvo la suerte de que lo atendiera un ser humano?
If you can stop whining long enough to do this, it will fix your Chromecast:
