Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-18-2025 01:49 PM
I uninstalled and reloaded from Google play to get v6! didn't work on my phone but did on my tablet!¯\_(ツ)_/¯
03-18-2025 12:17 PM
i had done the factory reset and now tried setting up my chromecast2nd gen, still same issues as before. Anyone was successful?
03-18-2025 03:24 PM
You have to set back the date of your mobile device. I had also to restart it. Then open the app and look for the chromecast to set it up. It will connect to your wifi, but you cant select it. Set the real date. Wait a few hours and try again. Worked in my 3 chromecasts.
03-18-2025 12:19 PM
Hej! Jag har gjort fabriksåterställning och inte lyckats få igång Chromecast. Har uppdaterat Google Home appen men det hjälpte inte. Testade nu att radera google home appen ladda ner den igen och då lyckades jag, ny mjukvara laddades laddades ner till Chormecast och allt fungerar nu igen. 😃
03-18-2025 12:34 PM
Its not fixed... It still doesnt working
03-18-2025 12:38 PM
try to delete the Google Home app and download it agin, it did work for me.
03-18-2025 02:03 PM
I did that to , but did not work
03-18-2025 03:37 PM
Delete Google Home. Re-download Google Home. Do a factory reset on the Chromecast. Add Chromecast as a new device using Google Home. -Cheers!
03-18-2025 11:27 PM
I manage to reinstall my chromecast and perform the update mentioned as a solution by Google. So all good now
03-18-2025 01:06 PM
The app version 3.30.1.6 did the set up of the factory reset chromecast. Thank you!
03-18-2025 01:46 PM
How did you get the latest app version? My version is 3.30.1.5. I can't find a place to update app
03-18-2025 02:04 PM
That is the latest I got to, 25 of february,
03-18-2025 01:07 PM
Olá, eu resetei meu chromecast, como faço para atualizar e voltar usar novamente?
03-19-2025 09:54 AM
Altera a data do seu telefone pra 01.03.2025e faz a configuração novamente
03-18-2025 01:15 PM
Both my Chromecast 2s aren't working, and now my Chromecast 3 isn't working either. What's going on?
03-19-2025 09:55 AM
Altere os dados do seu telefone pra 01.03.2025e faça a configuração novamente
03-18-2025 01:32 PM
I still cannot connect, i have the latent version of the application but still nothing
03-19-2025 09:55 AM
03-18-2025 01:38 PM
Onde se encontra essa versão do Home? Pois no playstore ainda está a antiga.
03-18-2025 01:48 PM
Eu fui um dos que fez a redefinição de fábrica, nisso fiz o seguinte;
1° fiz o procedimento normal de conectar, após identificar ele pede para confirmar o código na tela, nisso ao tentar ele da o erro;
2° eu não fechei o app google home, fui até as configurações de data, e mudei para ela para 01/03/2025
3° voltei no app do google e pedi para localizar novamente, ele pediu nisso qual wifi queria, selecionei o meu e coloquei a senha manualmente, após isso ele conectou e atualizou sozinho, reiniciou acho que 2x e pronto.
03-18-2025 01:52 PM
The problem still in my chromecast... so disappointed 😞
03-18-2025 01:59 PM
I have 1 hour trying to connect it! Still nothing!!! No update for google home app neither!!!
03-18-2025 02:06 PM
Works like a charm again, thank you verry much for solving this problem!
(I realy like Chromecast Audio, it brings my old studio speakers back to life.)
03-18-2025 02:13 PM
Not working yet. Edmonton Alberta Canada thank you.
03-18-2025 02:21 PM
So now my Home App won't acknowledge that it has permission to look for nearby devices. So I can't even try and connect to my Chromecast. Even though I've un-installed and reinstalled the app. That's the only way I could potentially get the updates, because there is no new update for the home app. Nz. What's going on? So frustrating.
03-18-2025 03:34 PM
Bisogna modificare la data del telefono al sei Marzo 2025 poi configurare Chromecast dall'app home una volta finito di aggiornarsi impostare ancora la data automatica del telefono .
03-18-2025 06:15 PM
Deu certo!! Obrigada
03-18-2025 06:15 PM
Deu certo!!! Uhuuuuuuuuuu mudar a data para 06/03 funcionou.. obrigada a todos
03-18-2025 02:26 PM
Para os falantes de português, mude pra uma data anterior ao erro ( eu usei 6 de fevereiro) faça a configuração e somente apos a atualização e finalização da configuração vc retorna pra data atual. Aqui voltou a funcionar!
03-18-2025 02:54 PM
Como faz essa mudança de data
03-18-2025 03:39 PM
Devi andare impostazioni ora e data del telefono e modificare la data a prima del sei Marzo poi una volta configurato Chromecast dall'app lascialo aggiornare , imposta ancora la data attuale del telefono oppure metti automatica dalla rete .
03-18-2025 06:16 PM
Obrigadaaaaaaa
03-18-2025 02:42 PM
Hey Google thanks a lot from Italy, i always believed in you.
My six Chromecast Audio are back to shine in my home.
I have been terrible days without Chromecast Audio and music, please never give up on them.
Have a good life.
Nox's Vibes
03-18-2025 02:45 PM
So where is home version 3.30.1.6 play store still has 3.30.1.5
03-18-2025 02:49 PM
I´m still waiting for the HOME version 3.30.1.6
It does not appear at Play Store...
03-18-2025 03:12 PM
hi... the last version of google home is not available en play store. When it will be available.
Thank.
03-18-2025 03:12 PM
Não recebi nenhuma resposta
03-18-2025 03:16 PM
Ainda bem com
03-19-2025 09:52 AM
Altera a data do seu celular pro dia 1 de março e faz a configuração do Chrome cast de novo que vai funcionar...quando terminar vc coloca a data certa no celular novamente
03-18-2025 03:15 PM
Your fix worked! I had done factory reset but updating Google home fixed that problem.
Thank you oh smart ones😉
