GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,145 REPLIES 16,145
Mugares
La version Google Home 3.30.1.6 en Google Play NO esta en la tienda.
BartW
Ja też nie mam jej w sklepie Play w Polsce. Przed chwilą pobrałem ją z APK Mirror. Moja dotychczasowa wersja została zaktualizowana i wszystko jest już OK.
Jadicro
Eso de "Gracias por tu paciencia" fué un eufemismo verdad!?
Sam9pak
Hello i have already done reboot
So thats y i couldnt able to connect with google chrome 2nd generation
plz resolve this isue as soon as possible already u took to many days  for reaolving this isue
Samira1
Sigue el problema de autenticar. Yo restableci de fabrica cuando empezó el problema.
Que puedo hacer?
Eugen123
Still waiting for the fix - of course I did the device reset and now I can't setup my device. That's really annoying...
Just got off the phone with tech.. This is **Only for those of us that factory reset, maybe even deleted device with intention of re-adding, and then kept getting "can't authenticate device" message**:  Open app store, update Google Home, open app, go to add device (or just connect device), during normal process it will auto-prompt updates to be done at same time (takes a hot minute for it all to download), should be golden after that.
Ben28
Hi there. I've been on the app store the past two days and have not seen the update for the Google Home App to update to 3.30.1.6.
Ahsaan24
3214Ahsaan24
Ahsaan24
My Life account
MKrealDons
Doesn't resolve the issue for reset devices. Says I need to activate the chrome cast using device utility (a defunct app)...
axmir
It is two days since your last update promising Google Home app version 3.30.1.6 for Android, yet as of today 3/19/25 the Google Home App is still on version 3.30.1.5 on the Play Store.  The Google Home app version 3.30.1.6 has not pushed to any of my Android devices.  How many days are there in a "few days"?
Scadogan
I still cannot set up my Chromecast
Peter_1
For those who have factory reset their device and updated google home to the latest version and things still don't work out, i have a fix.
You need two mobile phones for this, one with hotspot capabilities and the other with google home app.
1. Power down your home wifi
2. Set up a hotspot with exactly the same specifications as your home wifi.
3. Set the dates of both phones back to march 5th
4. Connect the other phone to your hotspot
5 open google home and connect to your chromecast
6 when prompted for wifi connection of chromecast, provide hotspot credentials
7 chromecast starts downloading the beloved google firmware updates!
8 go through the steps prompted by home app. If things don't go, just skip them untill google home says you're done.
9 disconnect power of chromecast, reset the dates on your mobile phone, turn off hotspot, turn on home wifi again.
9 wait untill you can connect your phones to the home wifi
10 reconnect power to chromecast and cast whatever you want!
Andres_Teixido
Hi, 3.30.1.6 update is not working, Ghome is not finding chromecast device, any suggestions?
Same!! I'm pissed!
I finally found phone number to Google support and I was told the new update to Home hasn't resolved the issue even though I'm blogs they say update works. +17038653826
Luizaaparecodas
E ficar entre difícil
Johnny74
Finally it works, have upgraded Home app to the latest version, was able to connect to 2nd gen Chromecast, obviously it did a firmware upgrade and I got it working again! It took a while, but it is fixed! Thx
DanielleMez
I was so excited. The update finally came through an hour ago. Did it? And now it's not working still, it's saying on one Chromecast, to hard reset it, because it belongs to someone else I did that. And now it won't connect at all the other one goes through all the steps and then fails to connect. Saying it couldn't connect. Couldn't connect to Chromecast. Failed. Fix this now! I'm so sick of this issue! What's through point of an update if it still doesn't work???????????????
Danitochromcast
Uso Google desde que tengo uso de razón en computadoras y celulares.. jamas un problema. Lo que ha pasado con Chromcast es tremendo!! Siempre confiamos en el sistema que nos brindan y que de un momento a otro pasara a ser un objeto obsoleto. Fue tremendo,..  Un golpe anímico a la familia! Ya que lo usamos mucho. Jamás debieron darlo de baja.. jamás.
Armando-Vet
Si Funciona mi Dispositivo
Como Reviso el firmware de mi Chromecast 2° Gen ( El Circular )
Me podrian Orientar , Por Favor
letizia
Ho scaricato l app aggiornata google home come da indicazione, tuttavia non riesco cmq a riconfigurare il Chrome cast perché il processo si blocca e si interrompe/ si impalla indicando problemi di rete ( che però non ci  sono). inutili i tentativi di ripristinare e ricominciare da capo
Whisperingcow
After downloading/installing the android update, I'm still having difficulty.  The Home app and device connect, but when I get to the point of communicating with my wifi I receive the following message: "Could not communicate with your Chromecast". Please advise...
Kmarx
Got my three Chromecast Audio devices back up and working properly.  Took a bit of doing, but had excellent help from Google support rep (thanks Jose!) and everything is working again.  If you're having trouble reconnecting you'll likely have to remove the device from Google home and add it back.  Might have to mess with other settings too so if your not sure I suggest getting a call from Google support and let them walk you through it.  My experience with their support was excellent.
ryanrichardamor
hard to update
davvidheater
i understand how frustrating it can be to deal with connectivity issues on Chromecast 2nd Gen and Chromecast Audio. Have you tried resetting the device and ensuring your Wi-Fi settings are optimized?
rafaelcosta9426
Rafael
DanielleMez
I will never buy a Google product again. I'm so pissed off that. Even after I got the update and did everything correctly. I still can't use either of my 2 Google chromecasts. I tried hard resetting factory hard resetting. Just like it asked me, chuxes said, I don't own this even though it's mine. And neither of them work, even with the update on my phone for Google Home. My Google Chromecast, will no longer connect to my internet. Due to your issue
Angie9
The problem persists always
Glor
Al final llegó la actualización,ya funciona 😁
Lululemon
Yaaay update came just in time for the SHL play-off ! 😄
2008lani
Hello mines is still not functioning. What do I need to do? Thank you
Anaclara
Luigy76
Ya está listo por si lo restableciste ,desinstala Google home y vuelvelo a instalar para que se actualice
Iwannagohome
I have that app version and my main chrome cast I use still isn’t back up.
FaresShawash
It is updated and fixed.
Thank you
BrandonGagne
Thank you, Google. In addition to updating the Home app, I had to CLEAR THE CACHE on the Home app.
0) Update the Home app.
1) Long press the Home app icon.
2) Press "App info."
3) Press "Storage."
4) Press "Clear cache."
Hello, when I press App info, nothnig happens. Just stays there. No next step for learing th cash. Any ideas?
dtarragona
I was one of who made the factory reset. I solved the problem by changing the phone date where I have the Google Home app to March 8th (the day previous to the problem). With that, my Chromecast 2nd was detected by the Google Home app, and I could move forward with the configuration process without problem. Once my Chromecast 2nd was connected to my wifi, it started the updating process and "voilà", my Chromecast 2nd started to work normally again! Kind regards!
