GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
pcl073
Same issue here. No resolution. I'm in Canada
Pendicle
Seems its a firmware issue. Outdated ssl whatever that is. A partial workaround is to manually change the date of your phone/tablet to 7th march, reconnect in google home, then reset your date back to network auto. Wont allow streaming, but will allow the firmware fix. Apparently.
It's not us folks it is definitely them!  They are currently working on fix... we probably tried factory reset... they say don't!
But if you have they will fix that too... eventually!
Read all about it here...
https://lifehacker.com/tech/dont-fix-older-chromecast-with-factory-reset-says-google
Efurlan
@GoogleNestTeam , do you have any news about solution?
LucaT
chromecast does not work. I also reset to factory settings, but when I connect this error appears.
Theaea
I have the same problem!
easy1988
got the 2nd gen , same problem
Same problem, did they roll something out to weed out the chromecast 2nd gen users? Feels like a 'you gotta buy newer products' set-up to me... Still hoping for a solution tho!
I have the third gen, same issue.
Uacata
Ho lo stesso problema!!
SebinParis
J'ai le meme probleme. Google Home détecte ma chromecast 2 mais ensuite quand je dis de configurer, cela indique "impossible d'identifier"
C’est vraiment désagréable effectivement
Scaramutti
I have the same problem .I couldnt reach any person to talk to .always authomathic responses that are useless
Elipaci
Same problem too. Is it Musk's fault?
Amy_Freddie
I’ve been trying to set up my Chromecast since yesterday. I’ve performed a factory reset several times, updated my phone, updated my apps, made sure my local network access is on. I’ve reset my Wi-Fi router and the light on my Chromecast is white. Everything seems to be working fine until I get to the end of set up and receive this message: TV may be set up, but we could not communicate with it from your iPhone. Make sure that you have enabled local network access in your privacy settings and try again. Ice even tried setting it up on a different TV.
Ho lo stesso problema da ieri hanno smesso di funzionare tutti e 4 i miei chromecast su 4 tv diverse. Home non li vede più
I have exactly the same problem. Also with a 2nd Generation Chromecast. It worked just fine until last week. Please help!
Exactly the same problem here. Worked fine until last night. It can’t be a coincidence that we’re having the same problem. Just need a fix from Google!
Same problem here!
It seems like the same problem is happening all over the world right now. It's probably a bug from the developers. There were a lot of comments on YouTube last night that were having the same problem.
https://youtu.be/pTAnF6wwa4o?si=mWJTX81CzmP8mMHL
Same problem here… Google needs to fix ASAP
Same thing here.. worked fine yesterday and now I keep getting errors and can not connect
Same problem here since last night, I tried to book several calls with Google, but the bot just hung up... I guess it must be a wider problem, hopefully Google will provide some information soon!
Wow, I thought that my 2nd generation Chromecast must be malfunctioning, but it looks like it's on Google side...
Mb1214
Two of my four Chromecasts are not working and, of course, I did a factory reset which evidently I shouldn't have done. I understand that Google can be glitchy, but this is really bad.
Marthaaaaag
I been having issues casting on my chrome it’s been 2 days already
Sean331
Following.
roomers
Signed up just to say I'm affected and too late for me to this statement "Do not factory reset your device"
kamal_01
hi
facing authentication problem in my Chromecast device since yesterday. is it firmware issue?
Cc2025
PUDE VOLVER A CONECTAR EL CHROMECAST CAMBIANDO FECHA EN DISPOSITIVO ANDROID Y CONECTANDO A LA MISMA RED WIFI. LUEGO SIN ACTUALIZAR LA FECHA EL DISPOSITIVO NO APERECE EN LAS APLICACIONES COMO FORMA DE TRANSMITIR.
SE VE EL MODO AMBIENTE. EN AMBOS CASOS.
CUANDO ACTUALIZO LA FECHA EN EL DISPOSITIVO ANDROID, Y QUIERO CONECTARME A YOUTUBE POR EJEMPLO CON LA APLICACION DE MI DISPOSITIVO ANDROID ME SALE LA LEYENDA "NO SE PUEDE VERIFICAR. ESTO PUEDE DEBERSE A QUE EL FIRMWARE DEL DISPOSITIVO ESTA DESACTUALLIZADO"
- POR FAVOR GOOGLE ESTO ES RESPONSABILIDAD DEL CREADOR ES DECIR USTEDES DEBEN SOLUCIONARLO O REENVIARNOS DISPOSITIVOS QUE FUNCIONEN. YO CUIDO MUCHO MIS COSAS Y NO ESTA ROTO USTEDES DEBEN ACTUALIZAR EL FIRMWARE DE LA APLICACION HOME PARA QUE CONECTE CORRECTAMENTE Y PODAMOS UTILIZAR UN PRODUCTO QUE COMPRAMOS. SOMOS CLIENTE GOOGLE. HELP ME!
Cc2025
LA FECHA A LA CUAL CAMBIE MI DISPOSITIVO ANDROID PARA CONFIGURAR EN APLICACION HOME MI CHROMECAST, ES 5 DE MARZO DE 2025.
Hola. Me está pasando eso hace dos días. En mi cel me dice que hay error en la autenticacion y me envía un enlace de Google. Que puedo hacer. Ayuda porfa
Lo reinicie varias veces y desintale el home del cel varias veces. Todo va bien hasta q me sale ese cartel en el cel y no puedo terminar la configuración. Ayuda porfa
ThaVilasBoas
Chrome parou de funcionar , mesmo depois dos resets,não conecta na internet . Como proceder ? 2 dias já
Trysnail
When will we get an update? So frustrating.
Mb1214
What are our options if we did a factory reset? That would be one of the first things to try when experiencing difficulty, something most people did, I'd imagine.....
Guilleermo
Lamentablemente desde el sábado 09 de marzo del año 2025 tengo problemas para conectar mi Chromecast 3ra generación con mi TV, dicen que Google desconectó estos equipos, por favor Google sean responsables y no nos dejen barados. Muchas gracias y espero su comunicación por favor. Espero que mejoren su reputación, sigo pensando que son responsables y profesionales.
Aquí sale que es problema mundial la desconexión de los Chromecast 3ra generación https://youtube.com/shorts/oYUgMGluHbo?si=4rCwqJp2I4V5CWX0
Paul41
Chromecast stopped working, couldn’t cast. Was working fine until now. Did multiple factory resets, Hone app sees device and  seems to progress and then at final step of connecting it always says “something went wrong”. No changes to router settings. Can see chromecast in connected devices on my router.
connected phone to chromecast SSID, but then Home can’t even see the chromecast anymore. Lost as to what to try next.
Desde ayer los 3 que tengo no van. Y Google no responde!!!!!
