GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,138 REPLIES 16,138
Santso
No puedo iniciar sesión
Santso
jotamasters
Olá, estava funcionando novamente, porém hoje voltou a ficar com problemas. Não consigo reproduzir a tela do dispositivo Android no Chromecast 2nd gen
KONTER22
aún es hora que no puedo configurar cromecast me cambiaré a firestick Amazon
AmangGrafika
Rajadewa138
RoshanSANDARUWA
Kapil15bhargava
I am still facing the issue
Hi u need to change the date and time manually to the date before it stopped working for all of us like January 1 and then try connecting to the device.. then the chromecast will download it's updates..one it does turn back the day and time to automatic to ur time zone ..
Vicki2
When is a fix coming for those who deleted the device from their home account, in an attempt to fix the issue?
Helloworldgoogl
Google fix for the problem of SSL certificate expiry in Chromecast has come. The device will Update the software automatically once it is connected. So you can connect your devices again and start using them
Shanti1
Hei!
En vieläkää saan Google homea ja Chromecastia yhdistymään. Ole tehnyt kaiken mahdollisen mitä olen ohjeita löytänyt... pariinkin otteeseen.. Chromecast jo uploadasi itsensä ja kaikki näytti menevän eteenpäin, kunnes se vain sammui.... ja nyt ei näy castin merkkiä TVssä ja Google home ei löydä koko laitetta ? Mikä avuksi... ? KOitin joapa vaihtaa päivämäärää, muta sekään ei toimi...
sharonbell5565
I don't have a Chromecast (2nd generation) Nor do I own a Chromecast  audio. My Google accounts are HACKED!!!
Bilissie
Mine is finally working again!!! I had left it unplugged for about 12 days. I plugged it back in and I saw that it was offline on my google home app(where it wasn’t even showing up previously). I tried changing the date on my iPhone but that just made it worse, so I went back to the original date, and I just re-added the device again, as I was mid way, the device updated itself and restarted and I just waited for it to load itself and followed the instructions and it eventually reconnected. Hope that never happens again!
yanaracidaliax
yes that ok
ZamanSaab
I need to get permission to access my photo video
Nandellajanne1
Pas opgelost , na datum van iphone naar 1 maart even terug te zetten.
Dfano11
It is still not working. The error message is "connection problem during setup". Please provide a fix asap. Tks!
hcandido
It was working until Friday 22th... And now is down again.
Firmware: 1.56.467165
Google Home app: 3.30.1.6
None of my streaming apps are working. I can see the Chromecast but it can't cast anything.
John98
Let me to connect the **bleep**ing Internet
mekoshawnwest
It's me
Rebien
My 2 chromecast 2nd gen still doesnt work.
I was one of those who made a factory reset, and I have the updatet home app. But it still want add my devices.
I wrote 1 week ago and still haven't heard anything
gustavo3
etc
Lu1983
On March 16, 2025, my Chromecast worked again -
But today, March 24, 2025, it does not work again - Is there an error again?
YvetteR
Same!
emmzone22
I'm having the same casting issues but it's from my Google TV Streamer.
YvetteR
It was working again, but on 24 March 2025 (Australia) it has stopped working again. What did they do?!
Log in to your Student Beans account
Betoraf
Otra vez volvió a fallar?, de la nada dejo de transmitir y ahora no conecta
SathishJK
Despite updating the google home, the chrome which I did factory reset intially still cant connect to the wifi network. I already restarted the router and other devices work fine with the wifi. How to overcome this? Is there a fix?
I had the same issue but my Chromecast audio was actually connected to the wifi network. The Google Home app just failed to see it and add it to the managed devices. However, I was able to cast to the Chromecast Audio from my phone without problems. Try it out.
msing002
I'm still having issues reconnecting my devices after the new version of Google Home was released for android.  I factory reset my devices prior to the response not to do so since it was a few days of not working.  Now it still has not been able to reconnect.  It goes through the process but once it connects, it cannot save the wifi and it's sitting right next to my router, password is correct, version of the app is updated.  Am I the only one still having issues?
Same here. It stopped working after a few days and now wont connect to my wifi no matter what i do
Msmonnbebe
Having the same issue again. Updated everything, worked fine, and stopped working again last night. Nothing will get it to work now! Ive had it.
joluca
El día 25 marzo 2025 Chromecast ha dejado de funcionar de nuevo : pantalla con el mensaje No se ha podido establecer conexión con la Red WiFi y el letrero A9N7
joluca
Funciona de nuevo: simplemente desenchufando y enchufando de nuevo.
ejmata305
Either Google doesn’t know what they are doing with their products, or they are just disabling their products so we are forced to buy new ones. I have some news, Amazon’s Alexa is working fine. They don’t even reply to our messages.
fogliad
I had the same issues with my 2nd gen chrome cast and audio cast devices, the latest home app 3.30.106 for iOS has resolved my issues, thanks.
Finally I can cast again!
015314293
Us2
Sweet..👍...mine work perfectly 👌..Thank..you guy's.☺️
Luca73
I managed to restore but the audio from streaming programs is not heard, in fact in some cases it is heard on the video preview then when you play the audio disappears
