GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
twftt
Doesn't work. Lost 2 Chromecasts to this ridiculous, and frustrating situation. Simply won't connect to the Chromecast. Have factory reset each device twice now. Simply won't install. Ridiculous.
