GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,147 REPLIES 16,147
Vicman92
Happened to me as well! Tried everything, but nothing works…
jccrispi
I'm getting the same thing here. I'm getting an error after a factory reset: "We couldn't authenticate your Chromecast..." Went to Play Store and told that on Google Home App reviews, then I was told to leave a feedback for the support, but the way they told me to leave a feedback doesn't work, once I have to do it accessing the device (Chromecast) and I don't have it anymore, I don't have any device on my Google Home. Always did a factory reset to fix things, and it used to work just fine. That's the first time something like that happens. I can even predict what's wrong here: every time a factory reset was done, Google Chrome allowed me to set up the Chromecast and then got updates from Google for the firmware, but now there are no updates because it doesn't even complete the setup.
SylwiaPoland
Device has stopped working. Cannot connect from any phone. Connection error or authentication error occurs. Hard Reset device performed multiple times. What is the problem? We have a second chromecast that works without a problem.
recanayr
If you did a factory reset, adjusting your phone's date & time manually would let you successfully connect to the chrome cast gen 2 again by temporarily turning off the following in order: "Automatic date and time" > "Set time zone based on location" > "Automatic time zone", from your Android device. Set the time to March 3, 2025 then, do a fresh start of Google Home App by closing the app and then open it again and try to add and setup the device. I successfully reconnected my device back into my home wifi network and back to "Untrusted Device" due to firmware issue again when trying to stream or cast videos. Now it is a waiting game for the GoogleNestTeam to fix the firmware/expired certificate issue. All the best GoogleNestTeam and goodluck!
alexregmunt
Não consigo configurar mais o Chromecast...repete...fiz tudo que pedem no tutorial e nada da certo
Semy
Parou geral... Ninguém sabe o que fazer?
Aqui parou também
Alguém já tem uma solução?
Aqui tbm parou e nada de conseguir a autenticação.
Moni2
Hola.
Por el problema global sin saber restablecí de fábrica el chromecast y ahora no me deja conectarlo al wifi. Alguien sabrá por qué ?
Hello.
Due to the global problem, I reset the Chromecast to factory settings without knowing it and now it won't let me connect it to the Wi-Fi. Does anyone know why?
ROLEAL
Tengo dos días tratando de conectar mis 2 chromecast, funcionaban bien y de repente ya no conectaron.  Ya me leí muchos artículos y vi varios videos en YouTube y instale y desintale Google home, quite los dispositivos y trate de conectarlos de nuevo y nada. Reinicie router y también los Chromecast desde el botón que tiene cada uno y nada. Y vine aquí y estoy viendo que todos tienen el mismo problema. Así que por lo menos ya se que es un problema general y de Google. Estoy en Guatemala y hoy es 10nde marzo 2025
Tengo el mismo problema, el mío es un Chromecast de 3rd generación y ayer funcionaba bien y de un momento a otro dejó de funcionar
Acabo de ver en X que parece que es a nivel mundial y los de Google están trabajando para arreglarlo.
AzaelS
La misma situación, ayer 9 de marzo 2025 dejó de funcionar sin razón aparente
ROLEAL
CCcamila3
Misma situacion, ayer de funcionar. Argentina 10/3/15
_Luis
Me pasa lo mismo y veo mucha gente en este foro y suman más y más cada hora. Creería que han descontinuado la versión de Chromecast que usamos, no se el modelo del mío solo se que tiene al menos 8 años, el de ustedes también es antiguo?
Thiago_Neto
When trying to connect the device to the internet, an error appears stating that the device cannot be connected in Brazil
Jokke12
Chromecast not work.
Problems was started last night.
"Device authentication failed"
Tamires
Tbm estou com o mesmo problema que começou ontem a noite!
Maria24
Jag tror att många har det här problemet nu, jag också
I går sluttet plutselig alle mine chrome cast enheter å fungere.  I Home appen står det "Uten nett". Er det samme problem du har? Det hjelper ikke å restarte.
A mi también me pasa, desde  no puedo conectarlo ni volviendo a los valores de fábrica.
O meu também começou a apresentar o mesmo problema desde ontem a noite. Já fiz reinicialização, desinstalei e reinstalei o home e nada.
Samma problem för mig! Otroligt. Var kan man få hjälp?
crisagaenaga
Ayuda, ya hice y reinicié todo y nomas no logro conectarlo.
sripadma007
I'm also facing this issue since past 24 hrs. Pls intimate me too once resolved.
xiexiexiexie
same issue
GiacomoMilazzo
As you know there's a world problem regarding the Chromecast that Google is attempting to fix (CA expired and so on)
For people, as me, that followed the troubleshooting guide, have factory reset the device and they weren't able to complete the configuration (no connection, authentication issues...) there's a trick.
Set the clock to have datetime manually and put the date back to 8 march, on the Smartphone where you've the "Home" app by Google and start the adding of the device. You will be able to do it, also if at the end it will not be usable. At least it will be connected to Internet (as from TV screen state) and we hope Google will upgrade them.
PS) I suggest to power off the Data connection (phone provider) to avoid an automatic change of datetime by network.
Thank you for the information about the set up after resetting the device. With the tablet having the old date I managed to communicate with Chromecast and fix the settings as before. Now I can watch photos from Google collections.
Thanks a lot ! The manual date worked for me as well.
Thanks, this workaround worked just fine. I changed my phone date to manual, set march 8th 2025, and then I was able to complete the setup from google Home app. I only see Google stock photos, I can't cast, so I will pray for Google to resolve this issue for all of us 🤖
Sei un grande! I've got my device back in my Home network.... Now, we gotta wait for the patch
Grazie
Deu super certo!!!!!
This did not work for me on my ipad after changing the date
I now have two bricked ChromeCast  - Doing the date trick on my iPhone wont make them connect. In the setup process everything goes as planed, but when coming to the Wifi setup I connect to the Wifi my phone is on, and is getting a "Connected" but then right after a "An error Occurred" message, and you can start over again.
This happened to everybody with a date after the expiring one of certificate.
Did you manually set the date of the phone running "Home" to i.e. march, 8th or before? Shutdown the data connection from provider to avoid automatic date by network.
How to stop network date
Is it on router settings?
No action on router. You've Home app running on a smartphone. Is there that you've tu set the date manually and then start the add of the reset device. Shutdown the phone provider data connection to avoid automatic changement.
I did that, but unfortunately I could not load many sites that I use, they probably check the date in the OS and refused to open. I switched back to the automatic time and date, and I lost again the Chromecast.
