GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
Dear Google.....my chromecast is not working anymore.  I've trusted you for years, but not my heart hurt in disappointment.  I can't believe that it won't authenticate.  Why are you denying me?
I have been trying for two days now.  Even switched to a newer TV and Chromecast.  Nothing is working.
Pls, see this msg from Google Nest Team:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro...
We need keep complaining since this problem should not had happened that way and must be fixed "as soon as all the huge resources Google have".
As I had commented on that post, I had already factory reset my device, as I think millions did since those were the previous instructions. That also shouldn't had happened.I
I'll post here any new information that I may receive. Pls, do the same and let me know ("tag me"), tks.
I also factory reset my chromecast. But I manually set my phone’s date before March 9, 2025 as someone's instruction, I did use the Google Home app to set up Chromecast again. My device is on the google home, but still can not cast anything.
Got the same error message here in Toronto. Suddenly can't cast yesterday around 11:00am. Tried factory reset and reinstall the Google Home but still not working. What's happening?
POSSIBLE TEMPORARY FIX:
It appears that someone at Google overlooked updating the essential certificate files for the Chromecast (2nd Gen) and Chromecast Audio, which is possibly causing the problem. One Redditor claims that the intermediate certificate authority for the Chromecasts (2nd gen) expired on March 9, 2025. Due to this, Google's servers are not validating these devices.
https://www.androidpolice.com/unable-to-cast-to-chromecast-youre-not-alone/
Pandee
I changed the date on my phone as was able to get it to work!!
the same issue, I reboot the chromecast, but couldn't authenticate it about on March 8,2025
Try changing the date on your phone to before March 8th and it should let you do it!
Maybe on March9,. When I manually set my phone’s date before March 9, 2025, I can use the Google Home app to set up Chromecast, but still can not cast anything.
Just here to say I'm also experiencing this.  I was going to reset it until seeing others had tried that, already.  This coincided with me linking to Nest and I thought that was the issue but it seems to be a coincidence.
Last night our chromecast wouldn't connect. Tried again tonight and still having the issue. Decided to reset it and add the device again. Getting the "can't authenticate" messenge.. looks like we aren't the only ones!
Dicen que es solo para chromecasts de 2da generación..  es cierto? Sería bueno coloquen cual generación o modelo tienen?
Same, issue, couldn't authenticate your device message, or untrusted device, mine is old. Any clew to fix it please.
Same here
When can we expect resolution???
Bruuu
Boa Noite,  o meu chromecast parou de funcionar,  não autentica... logo no início,
Já fiz todos os procedimentos possíveis, não adianta.
O que será que ouve?
Tem alguma solução?
tô nessa tbm, mesma coisa aqui
Muitas pessoas estão reclamando da mesma situação,  deve ter sido uma falha do Google, já tentei de tudo,  tenho 2 chromecast,  1 está normal,  mas o outro parou de funcionar, não sei o que fazer.
Você teria alguma solução?
O meu também já fiz de tudo e não funciona. Pelo visto não é só eu que estou com esse problema triste
Tomara que seja um erro e volte ao normal,  a minha TV não é smart e precisa do chromecast para conectar a alguns canais que assiste online.
A minha TV também. Sem o chromecast ela perdeu a função. Que absurdo o google não resolver isso.
Eu tô achando que desativaram os chromecast 2 , muito tempo sem resolver
Polyanne
O meu parou hoje 09/03/2025, reiniciei e na configuração aparece o erro, "não foi possível autenticar o Chromecast. Acesse o suporte...
Bruuu
perdemos o chromecast??
Darth1
O meu também parou no dia 9 de março.  Diz que não é possível autenticar. Reset não funciona
O meu também parou dia 09/03/25
Está todo mundo na mesma situação. E o google nada de resolver.
E acredito que tiraram as atualizações do chromecast 2
Bruuu
E o suporte não resolve o problema
Será que é uma falha no Google gente não é possível todos os cromecast pararem de funcionar. E logo no meu dia de folga acontece isso.
Eu acredito que é uma falha do Google
Will39
O meu tbm está assim
Gonzalonog
Si yo creo lo mismo, no es normal que dejen de funcionar de un día para el otro. Mañana se verá qué pasará
Ferrao
Aqui a mesma coisa. Já resetei 3x. O Google home não reconhece o cast
Milk1
Mesmo seguindo todos os protocolos não foi possível autenticar o chromecast. Alguem tem alguma informação oficial do que pode estar causando esse problema?
Bruuu
Também gostaria de saber,  estou achando que o crhomocash 2 saiu de linha
Chromecast para de
Google diz que os usuários não devem restaurar as configurações de fábrica. Solução está em desenvolvimento.
Eu resetei umas 05 vezes. Mas li em algum lugar, que mesmo quem restou o google vai dar o passo a passo. Quando? Só Deus sabe.
Mais , o problema é que as vezes é preciso reiniciar para resolver problemas.  Complicado.
Aldi80s
Monday 10, 10:54pm
Is there any new about the issue?
Thanks in advance !
Tane
So when is this update coming?
