GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,131 REPLIES 16,131
Marcella0610
È da ieri 10 marzo che mi appare "problemi di autenticazione" e ho provato entrambi i dispositivi che ho. Ho reinstalla home, ho retratto i Chromecast più volte, ma niente. Qualche idea?
amrzizo
Three days have passed and today the Chromecast does not work. There is no trust in Google products after today. The problem is that three days have passed and there has been no solution and no explanatory response from Google.
Aga2
Unfortunately, have  already factory reset my device, i an attempt to make it work and not knowing yeti that this is a global issue. I do expect you to provide  instructions to set mine (and many others, as I suspect) device back up as soon as possible.
amrzizo
Set the clock to the date before 3/7 and connect to the application. It will work for you, but it is waiting for the update from Google.
RcJazz
How do you reset the clock?
Oscar8
Changing date and time in your phone.
AndyMcCoy
Same here
Philip13
I didn't factory reset mine,  it still doesn't work
Andrewn2
I have factory reset it before found this article. What do I do now please?!
Same here
Carocas
Mismo problema. Reestableci uno. Igual el que no reestableci tampoco anda
AnitaK
Eso me ha pasado a mí ninguno de los dos funciona ni el restablecido ni el otro
Oscar8
The temporary fix is simple: set your mobile date one week back, then set up the Chromecast, revert the date and time, and wait for Google's next update.
Oscar8
The following workarounds, they honestly works like a champ! Check it out guys:
https://www.reddit.com/r/Chromecast/comments/1j7lhrs/comment/mgy1a88/?utm_source=share&utm_medium=mw...
Kira2
Asta cuando lo ban a restablecer asta que les dé la gana
  • Same here. Cannot connect to chromecast audio. Frustrating!
Anonymous
Not applicable
Don't worry... It will be fine....someday..
put date and time before march 8th and then try to pair chormecast again , it will not work but you ll have it like u never made the restore.
Oscar8
bugbite77
How about working on a fix for your Device Utility app too! What a Sh*t show Google is becoming!
cancel googledrive
Jaredgambrill
Ok. So how are you going to let me know when you have a fix? I have already factory reset my device
I also would like to know the answer to this question.
Same…
Same here
Same here
Change date on your phone to a date before 9th of march. It will let the device reconnect to the network. When connected to the internet it will not work due to understanding that the date is past the certificate. But is now connected to the internet = will get the push update from Google. (I don’t understand why Google isn’t writing this but.. yeah)
Sorry for my English; I'm writing from Spain, and it's not my native language. Your solution worked perfectly. Thank you so much. Google should wait until we all buy the latest Google TV model to replace the old one; they're so wrong. If something like this happens again, I will, without hesitation, buy a competitor's product.
Tu solución ha funcionado perfectamente. Muchísimas gracias. En Google deben esperar a que todos compremos el último modelo de Google TV para reemplazar el antiguo, están muy equivocados. Si vuelve a ocurrir algo así compraré, sin dudarlo, un producto de la competencia.
You're a Fu*king genius!!! It worked for me!!!!
NanceConfer
Nothing to update since yesterday?  What's up, Google? Day 3 and counting.
Is Google going to reimburse me if I have to go out and buy 5 Rokus?
lol  you can’t live without TV for a few days ?
Well, is going 4 days now, so...
suz4
Can still watch TV do you have any idea the crap on free to air TV in Australia that's why we pay to stream
Totally, depresses me to watch television after getting home from work. Hoping they fix the issue super soon.
When are you going to fix the cromecast connection problem ? It's been 3 days that cromecast stopped working.
I pay for 5 streaming services, that I can’t watch. So pr. day I loose 9 € / 10 $, now it’s 36 € / 40 $!
imagine if they destroy your family photos, cancel any cloud services and share this info
Do you have a laptop? Do you have HDMI port on your TV? If so, you can stream via your laptop, that's how I do now when chromecast doesn't work.
Si, tengo un portátil pero en él no tengo la aplicación de Netflix.
Netflix solo lo tengo en el móvil, y no puedo conectarlo con HDMI a la TV......
