2 weeks ago
I'm unable to remove the doorbell from it's mount. It has no wi-fi connection and seems to need to be reset. I have what I believe to be the hex key but it doesn't seem to do anything. Thoughts? Thanks
Stephanie
2 weeks ago
Did you change your Wi-Fi? If you did NOT, you could try just rebooting your doorbell by turning off the circuit breaker for the circuit that includes your doorbell for a minute or so to see if that brings it back online.
I don't know if this will be of any help, but this video at about 8:28 shows how the hex screw is tightened:
https://support.google.com/googlenest/answer/12570869
If your hex screw is stripped or broken, you could try contacting Support:
2 weeks ago
