03-27-2023 03:34 PM
Is it possible to have our Nest Hub automatically display our Nest Doorbell camera (2nd Gen) when the doorbell button is pressed? Currently, the Nest Hub stays silent but our 2 Google Home Mini's announce the doorbell - our old electronic chime goes off as well. Thoughts?
03-27-2023 04:52 PM - edited 03-27-2023 04:58 PM
You SHOULD get a "visitor announcement" (https://support.google.com/googlenest/answer/7672451) on your Nest Hub--displaying the doorbell's camera, unless your Nest Hub is set to "Do not disturb", or is in a separate Google Nest "home/structure" or on a different Google Account than your doorbell.
All of our Nest Hubs do so.
You could try contacting Support: https://support.google.com/googlenest/gethelp
You could also try removing your Nest Hub from the Google Home app, doing a factory reset of your Nest Hub, and reinstalling it.
03-27-2023 05:18 PM
Got it. Turned off Do not disturb and all is well. Thanks for the help!
