12-15-2021 03:52 PM
I just purchased the nest doorbell battery. The online instructions give both wired and battery only installation instructions. My question is: If you wire your doorbell to the current old system will the doorbell remained charged or will I still have to remove the system to charge it?
12-16-2021 12:18 PM - edited 12-16-2021 12:19 PM
So long as it’s getting the right voltage and power, it should be kept charged.
North America spec:
- Voltage: 8–24 VAC
- Power: 10 VA
- Frequency: 50-60 Hz
03-03-2022 08:53 AM
P.S thank you for your assistance, @Rubes!
03-07-2022 08:20 AM
Hey Folks.
