04-14-2024 05:42 AM
I recently transitioned to a new internet provider and had to remove my Google Nest Camera from Google Home so I can reconnect it with the new internet router.
The only only pulsates white and doesn’t change to blue. When I hit continue and go through the connection process in the Google Home app it says the following message:
"Something went wrong"
Try connecting again. If that doesn't work, try rebooting your device or turning your phone's airplane mode on and off before trying again.
I have tried everything listed, to include resetting the nest camera with no change. Can someone please assist in additional troubleshooting. Thank you in advance.
04-14-2024 07:29 AM
I've seen other posts in this forum from customers who have been unable to perform a factory reset on their battery doorbell.
Are you sure you've done a "factory reset" and not a "restart" (by pressing and holding the reset pin until at 10 seconds the status light blinks yellow 4 times with a countdown tone, and at 12 seconds the status light turns a steady yellow, followed by a confirmation tone)?
To reach Support:
04-14-2024 07:29 AM
To reach Support:
04-14-2024 08:14 AM
Thanks
that actually worked, I think I was just doing a restart!
04-14-2024 11:17 AM
Great!
