04-13-2024 02:40 PM
The nest doorbell will not mount after I took it down for recharging. It can mount very loosely but will fall off if anyone touches it. Please advice.
04-13-2024 03:56 PM
You could try contacting Support to see if you qualify for a warranty replacement. I've seen other posts regarding mounting problems with the battery doorbell.
04-14-2024 11:02 AM
Hey @Kristjanpp
That's frustrating to hear your doorbell isn't working right! Let's get this fixed.
To help me understand the issue better, could you tell me:
A picture can sometimes be worth a thousand words! If you're able to, could you also attach a photo of the back of your doorbell?
I'll be here to help you troubleshoot once I have this information.
Obed
04-14-2024 12:30 PM
Hello Obed.
I remove the doorbell by inserting a small metal piece under the doorbell.
There is a metallic button like thing on the backside it does not really move.
I bought it 16th of August last year from coolshop,com
I'm unable to insert photo. I attach a link from online to the same doorbell
https://www.digitaltrends.com/home/how-to-install-google-nest-doorbell/?amp
04-22-2024 12:28 PM
Thanks for chiming in, @MplsCustomer; I really appreciate it.
Thanks, Kristjanpp, for the information provided. I'm sorry to hear your doorbell can't be attached to the mount.
It sounds like the button might be stuck. I'd be happy to take a look into this for you by filling out this form for further assistance. Let me know once you're done.
Jenniffer
