01-19-2023 02:29 PM
I´ve bought a Nest doorbell (battery version) and I´ve it powered with a 20V AC transformer.
I would like to also make use of my existing Honeywell Home DW313 chime when someone pulses Nest doorbell.
There is no clear wiring diagram anywhere, explaining how to do it. My guess is that this will only work with this Chime connector that should be on the box since this product is advertised to work with electronic chime...
Am I wrong....?
01-19-2023 03:30 PM
Maybe the diagrams on this Google Nest topic will help:
01-19-2023 04:29 PM
Hello Mplscustomer,
This link is not for same product I have.... I have nest doorbell battery version, which can also be powered externally... anyway, in the link you sent the chime connector is being used... I think that in my case I will need it also... the thing is that this chime connector was not included in the package I bought:(
01-19-2023 05:04 PM
Sorry for not paying better attention to your post.
The battery doorbell does not use a chime puck/chime connector. You just connect it to your existing doorbell wires. But I don't know how your Honeywell chime is wired.
https://support.google.com/googlenest/answer/10732535?hl=en
As with the Nest Hello doorbell, there is a chime duration setting for use when setting up the battery doorbell with an electronic chime. I can't speak to how well it works with an electronic chime; we still have the older Nest Hellos.
01-24-2023 04:15 PM
burner, checking in — we hope you've got the answer you're looking for. Let us know if you have more questions in mind.
Archie
01-27-2023 09:18 PM
Archie
01-28-2023 10:12 PM
Hello there,
Thanks for the help, MplsCustomer and Archie.
