Painting Power Cable?
RavenManiac
I just purchased a black Wasserstein cover to better conceal my Nest Battery Cam. It works great! Unfortunately, the white Nest power cable ruins the idea. Is it okay to paint the power cable black, or at least the end closest to the camera that will be in view? Thanks!
EdmondB
Hello RavenManiac,
Thanks for reaching out to the Community .It seems that the black color option for the Nest Camera Battery power cable looks quite appealing. However, it's important to ensure that you avoid painting the area where the Pogo connector's pins are located, as this could cause issues with the connection.
Let me know if you have additional questions.
Edmond
