08-26-2022 09:10 PM
I installed my Nest thermostat last fall but now I get the message 'Low Battery Replace Now'. I removed my Nest and replaced the 2 AAA batteries but I still get the same message (FYI, I have a C-wire connected and properly installed).
I read some of the posts and came across doing a factory reset. I removed my Nest Thermostat in the Home App and then proceeded to do the factory reset. However, I cannot complete the installation because the app is telling me that I have to replace the batteries. Do I need a new Nest Thermostat? Help!!!
08-27-2022 06:45 AM
I was just having the exact same issue, I removed the batteries, cleaned the contacts on the unit and the batteries and it worked.
08-27-2022 06:45 AM
08-27-2022 11:49 AM
It worked! I was beginning to think that the internal battery is bad or the thermostat itself was bad,
Thank you so much!
08-31-2022 12:47 PM
Hiya rylescu,
I'm glad to see Stevie1's answer was able to resolve your issue! In that case, did you have any other questions or concerns we can address?
Jeran
09-04-2022 04:15 AM
Melba
