Nest wifi point going offline randomly
pxmdk
Hi
I have the Nest wifi consisting of a router and two points, recently one of the points have started going offline. And will only boot up if I pull out the power, and plug it in again. It seems like it simply freezes as the volume controls or other functionalities like voice assistant does not work until I do a hard reboot on it. then there can go up to a week, and same problem happens again.
Anyone have experienced this?
Semiponteva
Hi, I have same issue also. It started few weeks ago when I changed broadband provider.
AbigailF
Hello folks,
Thanks for posting and I'm sorry to hear about your issue. To clarify, have you tried doing a factory data reset on your Nest Wifi point? I'll wait for your update.
Abi
LovelyM
Hello everyone,
I'm checking in to see if you were able to do the steps above. I want to make sure everything is covered on your end, so let me know if you still need help.
Lovely
AbigailF
Hey there folks,
Abi
