06-29-2022 09:08 AM
Trying to set up my Nest Hub Max to a network that already has cameras and thermostat successfully connected to it. Plugged it in and followed directions with the Google Home App but not seeing the device. Tried every thing suggested - a different device to set up, force restarting the app, wifi on and off, even looking for the device on wifi - nothing worked. I finally went to factory reset it and I can't even do that! I hold down the volume buttons for ten seconds (and much longer) and nothing.
Any help?
07-04-2022 02:04 PM
Hey Henna,
Thanks for doing all those steps.
A few questions: is this the first time you're setting up your Google Nest Hub Max? Are you getting any message when connecting your device to your network? If so, can we ask when and where you purchase your device? Also, have you tried setting it up using a different network or mobile hotspot?
Alex
07-08-2022 10:32 AM
Hey Henna,
I wanted to check in and see if you managed to see Alex post? Please let me know if you have any questions from here. I would be happy to assist, and ensure you are good to go.
07-09-2022 10:55 AM
Hey Henna,
Just checking in to make sure that you saw my response. I'll be locking this thread if we won't hear back from you again in 24 hrs. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Alex
