01-10-2022 05:26 AM
When talking from the Nest doorbell to Nest smart hub the sound drops out so that you cannot understand what is being said through the hub (doorbell speaker is fine). On iPhones there is no issue with sound to the doorbell. I tried moving the hub next to the router, same problem. My niece has a similar problem but not as bad with hers. Is this a widespread issue? Any fixes please?
02-21-2022 05:07 PM
I have the same problem, was this issue solved?
02-22-2022 05:00 AM
No. I returned the Nest and bought a Ring doorbell from Amazon which works fine with Amazon screen.
