D+, HBO Max, Peacock won't play
NAVIPLO
Hello, I have a strange problem with Chromecast with Google TV 4K, Disney+, HBO Max and Peacock are not working. At the same time, YouTube and Netflix have no problems, they work normally. I reinstalled the apps, did a factory reset on Chromecast and the problem remains. Does anyone have an idea what to do?
9 REPLIES 9
JennySampough
We're having very similar issues, not sure what else to try either. Following this and will let you know if we find anything!
aatienza
I’m sorry to hear you’re having trouble with this. No worries, we'll check this out. A few questions: when did it start happening? Did you make any changes to your Chromecast settings? Are you getting any error messages while playing those apps? To isolate this, could you try casting them using your phone to see if it happens as well?
Archie
NAVIPLO
For me, this problem appeared as soon as I logged into my Disney Plus account. I am able to browse a library of movies, but after pressing the play button on the selected movie, it won't start. I haven't changed anything in Chromecast settings. An error message only shows me Disney+ saying to contact them. HBO, Peacock just doesn't play movies. I have another Chromecast with Google TV 4K, I have no problems with it at all. Otherwise, when I cast the same services from the phone, I have no problems, the movies play.
NAVIPLO
NAVIPLO
Update
After a long investigation where the problem is with streaming certain services, I found that the problem is in
Settings
Display & Sound
Advanced sound settings
Automatic: Enable
When this is checked I have a problem streaming but when I have checked
None: Never use surround sound
or
Manual:
and check only Dolby Digital, everything is fine.
I forgot to add an important detail about the problem.When the bluetooth headphones are connected to Chromecast, this problem appears, if it is through the speakers of the TV, there are no problems with any settings.
Aatienza,
can you please forward this issue to the Chromecast developers?
Thank you!
JenniferV
NAVIPLO, we appreciate you sharing that in the Community — it's a big help! I'd suggest you send feedback about this via your Google TV. Here's how.
JennySampough, how's it going? Have you tried the information shared by NAVIPLO? Do you still need help?
Thanks for the help here, Archie!
Jennifer
I sent feedback about this via Google TV app.
Thank you, Jennifer!
JenniferV
Hey NAVIPLO,
Thanks — every bit of feedback helps a ton! Give us a shout if something comes up, we're always here for you.
Jennifer
aatienza
I appreciate the help, Jennifer.
Archie
