Return to Home Screen When Trying to Connect to USB Hub Storage
pracom
I'm having the exact same issue as described in this post:  Chromecast with Google TV July update seems to hav... - Google Nest Community
I could previously access the storage using a higher power supply (at least 60 watts), which I am still using, so this is not the issue.  I have tried resetting the Chromecast with no change.  I can successfully see and access the storage card using the X-plore app but have no ability to see or format it through the Chromecast Settings>System>Storage menu.
Jeran
Hey there pracom,
I'm sorry to hear that your Chromecast is having issues with your USB Hub! I can imagine this is a pretty frustrating issue, so I'd be happy to help out. Let me just ask you a few questions to better understand the situation:
  • When did this issue start happening?
  • Is your Chromecast with Google TV up-to-date?
  • What type of storage device are you using in the Hub? (such as SD card, USB drive, etc.)
  • Are you able to swap to a different storage type to see if the Chromecast detects it?
Jeran
Jeran
Hey there pracom,
Did you have any more questions or need any additional help?
Thank you,
Jeran
Jeran
Hey pracom,
Just checking up,
Jeran
