01-20-2023 09:10 AM
I have 5G and wpa2. i dont think wpa2 is supported and that's why I can't set up voice remote. When I press back + home I do not get a blinking light. I think wpa2 is preventing this. So can I proceed without voice remote?
01-20-2023 09:18 AM
The voice remote does not work over wifi so 5ghz or wpa2 make no difference to it.
It could be that the remote is broken or out of battery. Have you tried changing those?
The device can also be used with the remote app https://play.google.com/store/apps/details?id=com.google.android.videos&hl=en_US&gl=US but I think for that it probably needs to have wifi already configured.
01-20-2023 09:18 AM
01-20-2023 09:45 AM
I am setting up a new device - straight from the box. The diagram pictures the blinking light on the bottom of the remote. My remote does not have it there. Instead there is a place for it on the top side middle. Using the new batteries that came in the box. Could they be defected?
01-20-2023 01:27 PM
Try new batteries just in case, if that doesn't help then maybe you got a defective control.
When I press home plus back on my remote I don't see a light either but mine is already paired, not sure if that makes a difference.
01-25-2023 08:23 AM
Thank you for helping out on this thread, InstantBits!
Hey there zan,
I'm just checking up on this thread, do you have any more questions or need any additional help?
Jeran
01-31-2023 12:21 PM
Hey there zan,
Do you have any more questions that we can address?
Thank you,
Jeran
02-01-2023 12:26 PM
Hey zan,
Do you have any more questions? If not, I'll go ahead and lock up this thread in 24 hours.
Just checking up,
Jeran
