02-14-2023 01:46 AM
Dear community
I use the following setup to hear internet radios:
Now, regardless of the internet radio streamed bitrate, Chrome seems to send to the Chromecast Audio the same bitrate of about 120 kbps. This would suggest to me some kind of transcoding happens internally to the browser, so that some strange (il)logic forces the Chrome browser or its standard audio player plug-in to transcode the audio stream BEFORE sending it to the Chromecast.
Oddly enough this happens even if the radio station bitrate is lower than 120 kbps. I attach some screenshots for reference.
Naim Radio 320 kbps
Radio Paradise Mellow Mix FLAC
Radio Paradise low bitrate (32kbps)
@djtetei - I read several posts from you on the matter, you seem to be a subject expert 😉, would be glad for your support
Thanks in advance
Giulio
03-14-2023 09:05 AM
Hey there merak2000,
I apologize for the late response, and I appreciate your patience! While I'm not an expert on the subject matter, transcoding is currently expected on certain sites that aren't Chromecast-enabled. Some users expressed interest in being able to add media remoting support for audio-only sites and avoid transcoding, and Google is always looking for ways to improve. In this case, I'd encourage you to submit feedback in the Google Home app. The more feedback Google receives regarding a specific feature, the more likely they are to prioritize it.
Let me know if you have any more questions, and I'd be happy to help where I can.
Jeran
03-14-2023 12:08 PM
Hi Jeran
thanks for replying. I actually was not aware there was a difference between "casting a tab" and having a "Chromecast enabled site". I was assuming that the communication protocol between Chrome and the Chromecast audio was designed in such a way
I realise that such an approach works provided that the downstream DAC (as in my case the Chromecast Audio is optically connected to a digital amplifier) is capable to decode such a stream.
Perhaps the Engineers chose a (very) conservative approach and decided, in presence of a Chromecast Audio digitally connected to an external DAC, to have Chrome feeding the device with something they were sure that any DAC would be able to handle (I suspect the 128kb/s MP3 stream I see is a good candidate for that)
This however cancels all the point of having a device like a Chromecast Audio connected to a high quality DAC (at least when the source is a browser). It's a also shame that just a few apps seems to be chromecast enabled (and I am not even sure Chromecast-enabled is the same as Chromecast-AUDIO-enabled, will check)
Many thanks for having taken the time to answer, and regarding the feedback to Google, well, I tried to discuss this with the google chromecast support. We are at the 20th email (and counting) and so far nobody among the 1st line support agents who wrote me seems to have even got a clue of the issue.
All what I could get so far are pre-written answer templates. That's very, very disappointing.
All the best,
Giulio
03-30-2023 09:12 AM - edited 03-30-2023 09:13 AM
Hi Giulio,
Thank you for your email. I understand your frustration. It is unfortunate that the Chromecast Audio does not support high-quality audio streams directly from the browser. I agree that it was a conservative decision by choosing to use a lower-quality MP3 stream, as this was likely made to ensure that the Chromecast Audio would be compatible with a wide range of devices. However, this decision does not work for users who want to use Chromecast Audio with a high-quality DAC. It would be great if there were more apps that were Chromecast-enabled, and if the Chromecast Audio could decode higher-quality audio streams. I'll definitely pass on your feedback to Google as well.
I hope this helps. Please let me know if you have any other questions.
Jeran
04-03-2023 10:17 AM
Do you have any more questions that I can address?
Thank you,
Jeran
04-03-2023 10:24 AM
Hey Jeran
no, thanks, no more questions.
I appreciated you forwarded the feedback though! 🙂
All the best
merak2000
04-04-2023 08:33 AM
Hiya merak2000,
No problem at all! In that case, I'll go ahead and lock this thread in 24 hours. If you have any more questions in the future, feel free to create a new thread.
Have a good one!
Jeran
