02-17-2023 08:27 AM
Hi everyone
I’m trying to get my wireless nest cam back up and running after moving it onto a new wireless network.
So far, I have deleted it from my Google Home / Nest app and reset it by holding down the reset button with a toothpick for 5 seconds (as per directions found online).
When I install it back into the Google Home app, it starts off well. I add it to the account, plug it in and it chimes and the white light shows. so far so good.
According to the set up, this should then turn to a blue light before I move to the next step. It never turns blue but eventually goes green instead. The set up steps then display an error message.
Have I not factory reset it correctly? Did I only restart it? I can’t find any definitely answers in the other posts about what the difference between the two procedures is. (I’m holding down the reset button for 5 seconds)
All help gratefully received!
N
02-17-2023 09:52 AM
Pressing the reset pin/button for 5 seconds are the instructions for "restarting" the battery camera. The instructions for a "factory reset" are to remove it from the Google Home app. The manual "factory reset" instructions call for pressing the reset pin/button for at least 12 seconds, until the status light blinks yellow 4 times after 10 seconds and you hear a countdown tone, and then at 12 seconds the status light is a steady solid yellow and you hear a confirmation tone:
https://support.google.com/googlenest/answer/9252162?hl=en#zippy=
What "error message" did you get?
02-17-2023 09:52 AM
02-17-2023 10:21 AM
Thank you! This is exactly the info I was after (and suspected that my factory reset wasn’t a full reset).
I held the button for much much longer and heard the three tones and got the yellow button. After a few failed WIFI connection attempts after this, it then went further through the new set up procedure and we are back up and running 🥳🥳🥳
02-21-2023 02:43 PM - edited 02-22-2023 03:03 PM
Hello everyone,
@NinaP1 thanks for getting back to us and for sharing what you've done to resolve the issue. We're glad to know that it's up and running now. We’ll consider this one complete so let us know if you have other questions or concerns as I will be locking this after 24 hours. Feel free to start a new thread and we'll be happy to help.
