Best Doorbell (battery) will not factory reset
Eboo89
Doorbell disconnected from wifi. Tried to factory reset but it will never do the count down chime. Have held reset button for over 2 minutes and doorbell will just cycle from green to white. Roughly 2 years old
ovidioj
Hello @Eboo89,
Thanks for posting in the community.
I understand you're having trouble resetting your Nest Doorbell battery, and I also appreciate your effort in trying it on your own.
Here are the correct steps; please follow them:
With the doorbell connected to its charger:
  1. Locate the reset pinhole on the back (below the USB port).
  2. Insert a pin (paperclip or thumbtack) and hold for 10 seconds.
  3. The light will blink yellow four times, and you'll hear a countdown tone.
  4. Keep holding for an additional 2 seconds until the light turns solid yellow and you hear a confirmation tone. This is the crucial step for a successful reset.
After Reset:
  • Your doorbell will appear "offline" in the app.
  • Remove it from the app. Settings > Remove Device > Confirm.
If the reset fails after following these steps, please let me know.
Jorge
