Best wireless and Chime
LJ67
Hi I am thinking of getting the latest Neat wireless (battery) door camera…. Are there any chimes that I can just use, preferably over WiFi?
any help would be awesome
JuanCH
Hi LJ67,
Thanks for reaching out to the community! I understand you're looking for information on compatible Wi-Fi chimes for the Nest Doorbell (battery). I'd be glad to help you with the information you need!
The simplest and most reliable 'chime' is to use a Nest Speaker. Since the Nest Doorbell is a smart device, it rings directly through any Nest or Google Home speaker you have set up over Wi-Fi.
To learn more about the Nest Speakers' size and colors, please check the following link: Smart speakers that entertain and help out
Please let me know if you have any other questions.
Juan
