07-02-2024 12:21 AM
I just received a nest doorbell as a gift and have been trying to set it up. When I plug the doorbell in with the provided cable the light goes white for about 5 seconds and then yellow for about another 5 seconds then shuts off. When I try connect it through the google home app it doesn't come up as I don't believe it is actually on. I've tried resetting through the little hole in the back and makes no difference. Is there something else I should try/do or is the doorbell faulty.
Thanks
07-02-2024 07:13 AM
Perhaps the battery in your doorbell needs charging. If the status light slowly blinks yellow, that's supposed to mean a "Battery issue":
If you leave it plugged in (it supposedly takes about 5 hours to fully charge - https://support.google.com/googlenest/answer/11052520) and still can't get the Google Home app to recognize it, you could try contacting Support:
