07-27-2024 05:54 PM
I changed my wifi password... I factory reset my nest camera and tried to set up my camera three times to no avail. Please advise. I went through your tutorials but nothing has worked.
It was working fine before I changed my password.
07-27-2024 06:51 PM
Did your factory reset complete, with the status light blinking yellow 4 times with a countdown tone after about 10 seconds, and a solid steady yellow light with a confirmation tone at about 12 seconds, as described here?
07-28-2024 05:17 PM
i had a similar problem after installing a new router/modem & i couldn't find any help online. after thinking about it for a couple days i thought to myself, maybe if i uninstall my wired outdoor nest cam then uninstall the nest app, then reinstall the app, then the outdoor cam then maybe it will work & it did. before that i tried everything else & couldn't get it to work. i hope this works for you as well.
07-31-2024 01:29 PM
Hi @RS1029,
Thanks for posting here in the community.
I appreciate you taking the time to post this informative content. Your tips will be valuable to many people.
Melany
