02-18-2023 11:54 AM
Trying to connect my Nest doorbell wired 2nd gen to Honeywell Home chime 916
02-25-2023 01:41 PM
Hi Karl11,
Thanks for reaching out here in the Community. The Nest Doorbell (wired, 2nd gen) has higher power requirements than most doorbells. For some installations, you'll need to replace the transformer for your doorbell. You need a transformer that is rated for 16-24 V AC, 10-40 VA to provide enough power to your Nest Doorbell. If you've already installed your Nest Doorbell and you see a blinking yellow light on the front, your Nest Doorbell isn't receiving enough power. Follow the wiring diagram in this link. Keep us posted.
03-01-2023 09:47 PM
I appreciate the help, Emerson.
Archie
03-02-2023 10:53 PM
Hello there,
Archie
