Door lock went offline on app but looks connected
Roykimber
My device went offline but the connection is fine.  I have a green light and when I reset it it turned green fine.  I am still offline on my phone app.
gmelanymelissa
Hi Roykimber,
Thanks for posting in the community. I understand your device is showing as offline in the app, even though the device itself has a green light and appears to be connected. I appreciate the effort in resetting your device. No worries, help is here!
To better assist you with accurate information, I’d like to confirm the following:
  • When did the issue start?
  • What specific device do you have? Is it a Nest × Yale Lock or a third-party device?
  • How far is your device from the router?
  • Are you getting any error messages?
  • Are you using the Google Home app or the Nest app?
Keep me posted.
Melany
