05-20-2023 09:13 PM
I have a google battery doorbell I’ve just inherited from family. It was flat when I got it and although the light flashes when plugged in it does not charge. I have removed from my family’s google home. I have tried a number of different cables and plugs. Same result on all. Any suggestions? I’ve assumed it’s out of warranty so no dice on that front.
05-21-2023 11:43 AM
What are you using to try to charge it? The Google Store says: "Nest Doorbell (battery) Typical: It takes approximately five hours to fully charge the battery using a compatible 7.5W AC adapter (sold separately)." However, perplexingly, Google Nest does NOT sell any compatible 7.5W AC adapter for the battery doorbell.
05-21-2023 04:55 PM
I've used 7.5W AC adapter, 5W AC adapter and multiple cords but nothing. Can't find any explanation as to why it won't charge. Any help appreciated!
05-26-2023 11:00 AM
Hi C-Mo,
Thanks for reaching out to us, and I’m sorry to hear about the situation. I’d like to take a look at this for you.
Have you checked your Nest Doorbell charging port to check for any possible dirt build up? If not, you can use a clean, dry cotton swab to clean it off.
I’ll look forward to your response.
Thanks for your help, @MplsCustomer.
05-26-2023 02:12 PM
Thanks Zoe. Gave it a go- no change unfortunately. The odd thing is that the light blinks like it’s charging when I connect it to the USBC but it wont actually charge.
05-27-2023 01:49 PM
Thanks for the follow-up, and I appreciate the gesture. What type of LED light that blinks on your Nest Doorbell (battery)?
05-27-2023 03:37 PM
White
05-30-2023 09:42 AM
05-30-2023 04:54 PM
I have. Still only get the flashing yellow/white light while it looks to be charging but clearly isn't. Can't get any activity other than that.
05-30-2023 04:56 PM
Sorry, also, when I do have the reset button depressed I hear nothing and the light doesn't change. So the two things it says will happen (below) don't happen:
06-16-2023 04:02 PM
Hello everyone,
@C-Mo, thanks for getting back to us and for sharing here the steps you’ve done to your Nest Doorbell (battery). We'd be happy to take a look into this for you. Please fill out this form with all the needed information. Let me know once you’re done.
I appreciate the help, MplsCustomer and Zoe.
06-20-2023 08:03 AM
Hey C-Mo,
We got your form — thanks for filling it out. Our team will reach out to you via email to further assist you. If you have any questions or concerns, feel free to create a new thread as I will be locking this thread after 24 hours.
