11-27-2023 04:42 AM
I have a Google wireless doorbell in the front of the house and a Google wired doorbell at the back of the house. It would be really nice if ringing the front doorbell(wireless) could trigger the wired chime through the back doorbell(wired). I also use home assistant for triggers but I don’t see this option in the Google app or as an integration event in home assistant. Please consider adding this feature.
11-27-2023 06:35 AM
That would be a helpful feature, but it might not be possible, since your Google Nest wired doorbell rings your indoor chime by physically closing the electrical circuit when the button is pressed.
11-30-2023 04:25 AM
Ahh, got it. I didn’t think a physical switch was used directly. I thought they closed the circuit with a relay or MOSFET and read the physical button as an input.
11-30-2023 08:48 AM
Maybe they do; I'm not a technical expert. But then to do what you'd like to see would require triggering a relay or MOSFET from a Wi-Fi signal from your other doorbell.
You could try submitting "Feedback":
12-02-2023 07:20 AM
Hello folks,
@EnDy, thanks for reaching out here in the Community. We hope that the information shared above sheds some light to your concern. Let us know if you have additional questions or concerns.
