Google outdoor camera power usage
jec970
Hello, I would like to know how many MAH does the google outdoor camera use when in live view, vs standby and also how may MAH does it use while its charging.   Thank you.
2 REPLIES 2
arm_dpe
Solutions Expert
Solutions Expert
Currently, there aren't specific features for direct communication with Google outdoor cameras to measure power consumption. To gather such data, you may need to measure it yourself using smart plugs with energy monitoring capabilities to measure the power consumption of devices like cameras. Plug the camera into the smart plug, and the smart plug into an outlet. The smart plug should provide data on energy usage over time. This method may not provide battery-specific metrics but can give insights into overall power consumption. Keep in mind that power usage can vary based on factors like outdoor temperature, voltage, and other environmental conditions.
EmersonB
Hello everyone,
@jec970, thanks for reaching out here in the Community. What was shared by armen_dpe is right on the spot and we hope that sheds some light on your concern. Let us know if you have more questions in mind.
I truly appreciate your response, armen_dpe.
