05-06-2024 03:14 AM
I am in Sydney, Australia and I am looking to install a wired Nest Doorbell. I can't find a specific "wired' one however. Do I just buy "battery" which can also be hard wired? Also, does it only come in white?
05-06-2024 07:21 AM
I'm just another Google Nest customer, but the Google Store post below says that only the 2nd gen battery doorbell is available in Australia.
https://support.google.com/store/answer/2462844
If you opt for the battery doorbell, you should be aware that it always runs on battery power, and therefore has limitations in cold weather climates:
https://support.google.com/googlenest/answer/11830989
When I go to the U.S. version of the Google Store, it shows the battery doorbell available in Snow, Linen, Ash, and Ivy.
05-06-2024 07:21 AM
