07-25-2023 05:28 AM
Loat qr code for indoor battery nest camera amd need to add back onto my wifi
07-25-2023 08:12 AM
When installing, you can select "Continue without scanning" and then use the 6-character alphanumeric Setup Code that is printed on the bottom of your camera.
07-30-2023 02:05 PM
Thanks for reaching out. I'm sorry for the delay. I just want to check if you managed to see the response above. Were you able to try the steps MplsCustomer provided? Please let us know how it goes.
You can check out this link for more information.
I appreciate the help, @MplsCustomer.
08-03-2023 11:31 AM
Hi Bethie1060,
