09-22-2022 06:53 AM
I had to do the maintenance work on the socket my camera was plugged into. After reconnecting my camere stayed off line in the NestApp. It wasn't found. I have the message to reconnect to the Wi-Fi. I went outside to scan the QR code off my camera and found the re is not green light on the camera.
Now my question is. How can I check the power supply to the camera. Is there any way of testing the power adapter? I tested the socket. All other devices plugged in works fine.
I do not believe my camera got buggered just by power it off.
Any ideas?
09-24-2022 06:43 PM
Sometimes, if there's a power outage, a couple of our Google Nest Outdoor Cameras won't come back online until I unplug them for a short while and then plug them back in. Others in this forum have also commented on this; it's a pain for customers with cameras at locations not close to where they live.
09-25-2022 05:58 PM
We’re sorry for the trouble. No worries, we’ll check this out. A few questions: did the camera work when it was first installed? If yes, how long has it been since installation? Is the customer using the USB cable and adapter that shipped with the camera? Is the Nest Cam Outdoor’s cable securely connected to the power adapter? Does the USB cable fit snugly into the port on the adapter? Also, are there any kinks or frays in the cable?
Here are some troubleshooting steps to try:
Let me know how it goes.
09-28-2022 09:05 PM
It's me again. I want to make sure you're all good — how did the steps go?
09-30-2022 08:02 AM
Archie
