Need different notification sounds for iphone
snooks
How can I change the notification sound? It now sounds like every other notification on my iPhone and I keep missing doorbell notifications and i can't find a way to change it.
RING doorbells have their own distinctive sounds which is so much better and also, Ring allow you to change the notification sounds. I'm starting to regret buying the google doorbell battery.
Why do you keep deleting my post? Are you trying to hide the problem? Surely it would be easier to fix the problem than to keep deleting the posts about it?
The people who buy this doorbell need to know that they are probably going to miss all of their notifications until you change the notification sound!
Cathal_S
Gold Product Expert
Gold Product Expert
Hi snooks,
I found the information linked below about changing notification settings on iOS.
https://support.apple.com/en-us/HT201925
Cathal
Cathal
snooks
Hi Cathal
Thanks for the reply but the option to change the notification is not available for the Google Home app so that does not work. If you were to allow the change in the app, then it would be a solution but it currently is not.
Cathal_S
Gold Product Expert
Gold Product Expert
Hi again,
Sorry that didn't help, I didn't realise iOS was so restrictive.
This is a community forum and I'm just a general user myself. The best way for leaving feedback or feature requests for the Google Nest team is by using the option within the Google Home app, this will be sent directly to the people that can make alterations.
Feedback:
https://support.google.com/googlenest/answer/7071494
Cathal
Cathal
Thanks for visiting the Community. Since this thread hasn't had activity in a while, we're going to close it to keep content fresh.
We hope you were able to get the help you need, but if you're still having trouble, please feel free to submit another post, and provide as many details as possible so that others can lend a hand. Hope this helps!
