02-19-2022 12:17 PM
I bought a Nest Cam Outdoor in NOV 2021. The power supply has failed, and I would like to request a replacement. The camera still works if I use a different power supply, but the one that came with the Nest no longer is providing power from the USB port connector. Please advise.
02-19-2022 10:03 PM
I have the same problem. Bought about the same time and now using my own usb adapter. Socket is indoors so no problem with weather…..
02-20-2022 06:41 AM
02-20-2022 07:00 AM
It is the original Nest Outdoor Camera that has the long power cord and round USB adapter. The USB adapter no longer provides power. The unit was purchased new in NOV 2021, so it has only been in use for 3 months.
02-20-2022 09:17 AM
Mine is the same. Nest are sending me a new plug foc under warranty…..
04-27-2022 11:53 AM
Thanks for visiting the Community. Since this thread hasn't had activity in a while, we're going to close it to keep content fresh. We hope you were able to get the help you need, but you might want to check out this support website article to learn more about the warranty of your devices and a link to reach out to our support team.
Should you need help in the future, feel free to submit another post, and provide as many details as possible so that others can lend a hand. Hope this helps!
Edward
02-20-2022 11:01 AM
We have three Google Nest Outdoor Cameras, with the power cables feeding to the USB adapters inside our detached garage. They are 22 months, 17 months, and 9 months old. I hope ours last, since the USB adapters aren't sold anymore. It seems crazy we should have to worry about them failing so soon, and even crazier that Google has ceased making them for cameras that are still relatively new.
02-20-2022 06:26 PM
I recently bought four of these cameras and had them installed. Y OnTech through Google. The tech ran one wire along the inside of my garage door. After using it for a month the wire frayed, the camera is dead and it caused circuits to trip. Not sure if it is worth contacting f OnTech to have them replace the cord, but it’s crazy it would be an easy fix if I could just buy a replacement cord/adapter.
