Nest Cam outdoor charging cable
WiSo
Has anyone been able to find a 1 meter outdoor charging cable? If so, where. I see one on Amazon with lots of bad reviews so probably don’t want to go there. Would think there’s an OEM version available.
DeboraJ
Hi @WiSo,
Thanks for reaching out to the community! It sounds like you need a charging cable for your Nest Cam Outdoor. Let me see how I can help you find the right one.
The 1-meter charging cable you're looking for is available on our Google Store. Please follow the next steps:
  • Please click on the following link to go to Google Store and select your country.
  • Search for the following: Nest Cam (battery) Charge Cable, and you will be taken to the product page.
  • If you are looking for a different cable, you can find our other options in the accessories section.
If you have any other questions. I'm happy to help out.
Debora
DeboraJ
Hi @WiSo,
Debora
WiSo
Hello. Unfortunately the 1m cable is not the outdoor one. The shortest outdoor one is 5m.
DeboraJ
Hi @WiSo,
Thanks for that information! To make sure we're on the same page and you have the product I'm thinking of, could you please send me a screenshot of what you see for the product in the Google Store?
Debora
WiSo
Do you have an email address to send the screen shots. I don’t see a way to attach them.
DeboraJ
Hi @WiSo
Based on the information you shared, I understand you're looking for the weatherproof cable for the Nest Cam (battery). Currently, we only offer the 5-meter version for this product, which is the best option we can recommend for your camera's purpose and location.
Please do not hesitate to let me know if you have any questions! I would be happy to assist you.
Best regards.
Debora
