06-04-2025 05:37 AM
I'm looking for some assistance. I purchased and installed a wired Nest outdoor camera with floodlight. I followed the directions to ensure it was installed properly and can confirm it turns on and gets power.
During installation (after I scanned the QR code), I received a notification that the camera needed to download an update (which stalls at 1%). I've tried everything from restarting the device and resetting the router to moving the router to the room closest to my camera—nothing helps. I have already done a factory reset, and yet again, the software update gets stuck at 1%.
The Nest doorbell I installed on the same account and house has no issues and is running perfectly fine.
Any and all insight is greatly appreciated, I really just want the product I purchased to work.
06-08-2025 05:52 PM
Hi @jackie07,
Thank you for posting in the community. I'm sorry to hear your Nest Cam with Floodlight is stuck at 1% during the update. I appreciate the information about the troubleshooting you've tried with no success. I'm happy to help.
Since you mentioned having performed a factory reset on your Nest Cam with Floodlight, please confirm if you followed the steps below that show how to properly reset your Nest Cam with Floodlight:
Please keep me posted. I'll be waiting for your response.
Anders
06-19-2025 05:15 PM
I gave it a whirl and it seemed to work. But, on the Google Home app I am unable to set up the settings for the floodlight, shows up as an "Internal Error".
