Nest Camera picture goes purple
Chidham11
I have a nest aware camera and at certain times in daylight I have a purple colour on certain parts of the picture. And later it disappears. Any help please
EmersonB
Hi Chidham11,
Thanks for reaching out here in the Community. This can happen if your Nest Camera gets too hot or too cold.
  • Do not use indoor Nest Cameras outside. They're not designed for outdoor use and have an operating temperature range for indoor environments.
  • Place outdoor Nest Cameras under eaves or in shady spots so they don't overheat during very hot weather.
  • Your Nest Camera’s video might also have a pink, blue or purple hue if there's a problem with the Night Vision.
Give these steps a try:
  1. If the Night Vision settings are on Auto, switch it to Manual. Then, manually toggle the setting on and off. Observe the feed to check if the pink or purple tint goes away when they toggle the Night Vision settings off.
  2. Unplug your Nest Camera from the power source, wait for 30 seconds, and plug your Nest Camera back in. If you have a Nest Cam (battery) or Nest Doorbell (battery), you must also restart your Nest Camera or Nest Doorbell.
  3. Ensure your Nest Camera is installed in a supported location and not in an area prone to overheat or direct sunlight.
  • Just a reminder, overheating can cause issues with video feed quality. You may try moving your Nest Camera from a warm location to a cooler area to help resolve the issue.
        4. Unplug your Nest Camera from its power source and reposition it after it’s had sufficient time to cool.
Hit this link for more information.
aatienza
I appreciate the help, Emerson.
Archie
aatienza
Archie
AbigailF
Abi
