Nest Camera with Floodlight Not Executing Routines
Jammer
Remotely managing a second home where I've set up a couple of Floodlights. Need one of the Floodlights to come on at sunset and off at sunrise.  Set up routine which turns Floodlight on but second routine doesn't turn them off. Manually running routine doesn't work but tapping Floodlight in Google Home App manually does work for turn them off/on. So remote connection is good - but routine isn't consistent. I've tried deleting and redoing the routine. I've tried adding a voice command within the sunrise routine...
Also notifications aren't coming through even for the routine that does work (turning On the Floodlights at sunset).
13 REPLIES 13
EmptyNester
Gold Product Expert
Gold Product Expert
Hello, I'm and end user like you.  I don't have one of the floodlight cams or I would give it a try.  It looks like you have everything set correctly.    For this you may want to speak with an actual Google Tech on the phone.  Here is the link to  get that set up.  I believe they are there 24/7.  If they solve it please return here and let us know what it was as it will likely help other people in the future.
Jammer
Thanks for taking the time to reply.
I saw others with similar issues and it sounded like they resolved it without a Google tech so hoping I can hear from one of them….
Thank you, @EmptyNester for your help on this one! Y'all are in safe hands. Please let me know if you need further assistance.
Jammer
I changed the Routine to Turn Off the floodlights from Sunrise to 15 minutes after Sunrise. Thinking that maybe it's struggling with Sunrise, even though location etc is set.
3 days in and it seems to be working, I'll update again after a longer period of time.
@Jammer
Glad to hear it is working at the moment for you, but please continue to monitor and reach out if you need further assistance.
janthadeus
I want to check if you still need help. Don't hesitate to reach back if you do.
I appreciate the help here, EmptyNester and Brad.
Jammer
Still not working as expected. Testing different routine adjustments but no luck yet. Unless of course there is a known issue with Nest Floodlights being controlled independently by Google Home Routines.
@Jammer
Sorry to hear it isn't working as expected. We’re always looking for ways to improve, and appreciate your feedback. You can send it at any time using your devices by saying, "Hey Google, send feedback," or by following the steps found here
janthadeus
I appreciate the help, Brad.
The routines seem to be running properly over the last week. Fingers crossed.
janthadeus
Hey Jammer,
Cool! Good to know that. Let's observe it for now. Keep us posted.
Ebedia
Hi Jammer,
How's it going with the routines of your Nest camera? I just wanted to know if you have any updates. If you have other questions and concerns, feel free to let me know.
I appreciate the help, JT, Brad and EmptyNester.
janthadeus
Thanks for chiming in, Emerson.
