02-10-2023 09:46 AM
i have 4 nest drop cams. I've had them for approximately 10-12 years and never encountered any problems with changing wi-fi network (when I've changed to new routers). Recently, I mistakenly reset my router. I was able to attach my nest doorbell to the new wifi, however, i've not been able to attach the cams. I tried reconnecting 2 cams by way of factory resetting them. I've not been successful… no matter what I try. Help… please
02-10-2023 03:25 PM
Thanks for the suggestion and no I had not/have not tried what you’re recommending. Given my situation ($$$ to purchase replacements), I will give it a try. Will let you know the outcome. Thanks I’m advance for the recommendation.
02-18-2023 03:06 PM
Hello renorhea,
I'm dropping by to ensure that everything is covered here. How's it going with your Nest Camera? Were you able to perform the steps I’m suggesting and check the link I've shared? We'd be glad to hear from you.
02-10-2023 12:00 PM
For many (some?) Google Nest devices, when changing Wi-Fi settings it seems things work better if you remove the Google Nest device from the Google Home app or Google Nest app while still on the old Wi-Fi network BEFORE doing the factory reset and re-installing the device on the new Wi-Fi network.
Perhaps you would have success if you were to temporarily set your router back to its old Wi-Fi settings and try to factory reset your Dropcams using the instructions below:
https://support.google.com/googlenest/answer/9252162?hl=en#zippy=%2Cnest-cam-or-dropcam
It's just a thought, but maybe you've already done this.
02-10-2023 03:25 PM
02-15-2023 02:54 PM - edited 02-18-2023 03:05 PM
@renorhea thanks for reaching out here in the Community and for sharing your issue with us. I just wanted to make sure everything is taken care of. We wanted to know if you have any updates regarding the steps suggested by MplsCustomer above. In case you haven't done any steps, you may try these as well:
02-18-2023 03:06 PM
Hello renorhea,
02-18-2023 03:42 PM
As I have a nest doorbell cam and 2 outdoor nest cam, these are still a work in progress. That said, I still haven’t been successful at getting my drop cams online. I have one other ideal that I’m going to check out.
02-19-2023 07:50 PM
Understood — keep us posted. We’re here to help.
I appreciate the help here, MplsCustomer and Emerson.
02-22-2023 07:56 PM
02-23-2023 09:12 PM
Hello there,
I appreciate the help, JT.
Archie
