Nest Flood Light Settings
JCT66
Is there a way to program the floodlight to turn on automatically with a constant low dim setting from dusk till dawn to light my entire yard?  For example, at dust, the flood light would turn on at a low light setting, then if motion trips the flood light, the lights would turn on to it's full bright setting, and then return to it low light illumination.  So far, I'm only able to toggle the light on or off through the app, or it's either completely off with no light until it's tripped by motion, then full brightness for approx. a minute, then turns off-no light.  Our yard is pretty dark and it would be nice to have some constant light that's not the full 2400 lumens.  Thanks
I apologize for my late response and thank you for all of your patience while waiting for a reply. I understand how frustrating your situation must be, and I would love to help however I can. Do you still need assistance?
Best regard,
Just checking in on this thread and the activity on it. We'll leave this topic open for another 24 hours in case there are any follow up questions or comments.
