03-07-2022 07:37 AM
We are hearing a rustling sound when looking at our outdoor cam from iOS devices, although there is no such sound. Sounds like water is running somewhere, so we had to get the neighbors check out our yard when we were gone. So this is very annoying.
Does the camera need to be replaced? It also has intermittent WiFi connectivity issues although WiFi strength from the Nest Wifi router is strong.
03-15-2022 10:46 AM
03-16-2022 06:17 AM
Problem still there, and still no resolution
03-16-2022 08:58 AM
If your camera is installed near a water pipe or gutter, that could be what it is recording. Not sure what to tell you about this sound. Best to try and look at your settings, limit the sensitivity on sound, or give it a good restart or factory reset and try again.
03-21-2022 11:07 AM
03-24-2022 11:19 AM
Just checking in to see if you still need assistance with this issue. We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
03-25-2022 01:21 PM
Hey Folks.
