Nest Outdoor Camera
Jnrsadqi
Hello Community
my nest outdoor cam is installed in a high point of the building and I cannot locate the picture of my qr code prior to install. I have my serial number from the nest tech info details. Is there a way to connect without having to climb ladders to check the code?
S3bryan
Sadly no, it’s on the camera itself.  Use your camera to take a photo and keep it.  Remember it’s a 6 digit code you need and it’s on the camera.  It’s not the serial number you need
Just checking in to see if you still need assistance with this issue.  We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
Hey Folks.
