09-14-2021 07:30 AM
Cannot get doorbell to connect to router in home app. Please advise
09-17-2021 09:07 PM
I am having the exact same problem. Have you figured out a solution?
09-17-2021 09:33 PM
The only thing I can think of is make sure you are on the newest version of the Google Home app. Go to the App store and see if there is an update available
09-20-2021 11:38 AM
Terribly sorry to hear that you are having connectivity issues with your Nest Hello Battery doorbell! I would try to restart your Doorbell, the wifi, and like mdr2 stated, check for app updates. Please let me know if that does the trick!
09-23-2021 08:00 PM
cant connect to you assisting device.how can i fix
09-24-2021 09:01 AM
Wondering if you still needed assistance with this issue? Please let me know!
09-27-2021 12:10 PM
Hey Folks.
We haven't heard any updates from you. I'll go ahead and lock this thread. If you're still experiencing problems, feel free to start a new thread and we'll be happy to help.
10-01-2021 11:39 AM
I am having the same issue. Setup Google Nest Hub no problem to my Google Mesh WiFi, but the doorbell will not connect when I try to add a devise. It has me first install through the Nest app, then prompts to scan QR code, which then has you go to Google Home App. From there I try to add the doorbell and it says I need to use the Nest app….and the cycle repeats.
10-01-2021 12:33 PM
It sounds like you have no migrated your account from Nest over to Google Home App. Before doing that though, I would factory reset the Doorbell a few times which tends to do the trick. Please let me know if that does the trick.
10-01-2021 03:17 PM
Working now, thank you!
10-05-2021 01:49 PM
It looks like we have come to a solution so I'm going to be locking this thread. If you have any other concerns or questions, please feel free to create a new thread.
Have a great day.
Garrett DS
