Nest cam battery does not charge
Emusic32
The nest cam battery worked for many hours and then I was not able to charge the battery after that.
@Emusic32
Do you have the charging cord plugged in so that it feeds towards the FRONT of the camera?  Did you dismount it to charge the battery?  Is the status light pulsing white when it is plugged in to charge? (https://support.google.com/googlenest/answer/9268073
If you can't get it to charge, you could try contacting Support:
3. Select your device from the dropdown, click "Other", then click "Next step".
4. Under "Resources", just click "Next step". (Clicking one of the listed links will bring up a Help page.)
