Nest cam battery, replacement mount.
alacync
Is it possible to get a replacement magnetic mount for a nest cam (battery)?
6 REPLIES 6
Luke77
I have been looking for a replacement mount for a while now and have come up short until I found this on the Curry’s website that seems to tick the box.
not sure where you are in the world but curry’s is UK based and I’m sure there are other companies that sell these for their cameras.
https://www.currys.co.uk/products/toucan-wocmgt-wireless-outdoor-camera-magnetic-mount-white-1023574...
Luke77
Failing that you have this on Amazon but I’m not sure how I feel about a convex magnet in place of a concave one, still worth a shot.
Metal Magnetic Mount Camera Security Ceiling/Table/Wall Mount Compatible with Arlo, Arlo Pro, Arlo Pro 2, 3 Pack (White) https://www.amazon.co.uk/dp/B07BQNGS17/ref=cm_sw_r_cp_api_i_NXBGXMHWRYJFSNAXNTCA
Thank you for your patience. We do not process these requests in the Nest Community Forums. If you are seeking a replacement, please note that unless the device is under warranty, we cannot issue a replacement.
Please first fill out this form so Support can collect some important information from you. Once the form is submitted, you will have your case number.
Jeran
Did you have any more questions or need any additional help?
Thank you,
Jeran
Just checking in to see if you still need assistance with this issue.  We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
